JLYC Posted May 28, 2004 Posted May 28, 2004 I just got my 1/60 superstrike vf-1s. When I tried to transform to gerwalk mode, the two pegs from the legs (which act as the hip joint in battroid mode) keep on running into each other because there is not enough room. From the toy galleries, I also see that the hip joints can not be positioned side by side, but rather you have to stagger them in gerwalk mode. This results in the legs being kind of crooked. is is normal and is there a solution to this?? thanks Quote
wolfx Posted May 28, 2004 Posted May 28, 2004 For me, the pegs can be positioned one on top of the other. Looks abit messy underneath, but the legs would look fine. Quote
newca Posted May 29, 2004 Posted May 29, 2004 I just got my 1/60 superstrike vf-1s. When I tried to transform to gerwalk mode, the two pegs from the legs (which act as the hip joint in battroid mode) keep on running into each other because there is not enough room. From the toy galleries, I also see that the hip joints can not be positioned side by side, but rather you have to stagger them in gerwalk mode. This results in the legs being kind of crooked.is is normal and is there a solution to this?? thanks me too, I don't like this, so I sold up all my 1/60s last year. Quote
irishman Posted May 30, 2004 Posted May 30, 2004 I also have this issue, is there a common transformation solution that I am missing other than having the leg pegs bang against each other? Irishman Quote
Chewie Posted May 30, 2004 Posted May 30, 2004 I remember someone saying that (and it worked when I had a yammie) if you forced a portion of the legs out (don't quote me, and if you're watching Mr. Guy Who Posted, tell them) under the chest piece?? that the legs would look great, be a lot more stable and the pegs wouldn't be a problem. Quote
do not disturb Posted May 30, 2004 Posted May 30, 2004 its just one of the design flaws of the 1/60's...it drove me nuts for a while too. i keep my 1/60's in either battroid or fighter modes and display 1/48s in gerwalk mode. its not really a solution but the 1/60 has the nicest(IMO) fighter mode and more accurate battroid mode. the 1/48 has the best gerwalk mode. Quote
