ewilen Posted March 9, 2004 Posted March 9, 2004 www.macrossworld.com doesn't resolve on my home computer. I can still connect at work, probably working from a local cache. Tried doing ping and traceroute to the nameservers listed in the WHOIS record for MW, but both tests fail--testing both from home (DSL) and work (T1). Quote
azrael Posted March 9, 2004 Posted March 9, 2004 Everything is working on my end. C:\>ping macrossworld.com Pinging macrossworld.com [66.98.160.20] with 32 bytes of data: Reply from 66.98.160.20: bytes=32 time=62ms TTL=48 Reply from 66.98.160.20: bytes=32 time=94ms TTL=48 Reply from 66.98.160.20: bytes=32 time=62ms TTL=48 Reply from 66.98.160.20: bytes=32 time=62ms TTL=48 Ping statistics for 66.98.160.20: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 62ms, Maximum = 94ms, Average = 70ms Quote
ewilen Posted March 9, 2004 Author Posted March 9, 2004 (edited) MW itself is up (and pingable), but I can't get the name to resolve to an IP address from my home computer. Your web browser or your computer may have the IP address cached, or it may be cached at your DNS server. I also can't seem to access the two nameservers at rackshack.net using the server command within Unix nslookup. EDIT: as of this edit, it looks like the problem is gone. Thanks to whoever or whatever is responsible for fixing it. Edited March 9, 2004 by ewilen Quote
