HELP!! My new VF-22S MAX has a wing sag
This question seems to crop up every six months or so.
Bear with me, I'm trying to do this from memory.
Open up the landing gear doors (by the wingroots). You should see a screw (or two) inside the landing gear bay next to the wing. If you tighten (or loosen) that screw a bit, it should help to make the wing stay in place better and eliminate any sag.
That's why I put it in parentheses, DH. Gotta give all possible options and solutions. ;)
WOW! This actually REALLY helped mine!
I had to loosen the screw. If you take it slow and easy, loosen a little bit and test the wing, you'll find the perfect screw position. And I just opened myself up to all kinds of sexual jokes there. :unsure:
Thanks for the tips on FIXING my VF-22s Max. Really appreciate it! :D
