Thai Boxer 9901 Posted July 29, 2007 Posted July 29, 2007 So I was watching EP.1 of Mac Zero the other day and when you see Roy transform the VF-0S for the first time, I noticed that on the Engine/Leg intake, the intake covers open up but on the VF-1 they get closed??? Im assuming this is because of the difference in engines between the 2? The VF-0 with overtuned conventional jet engines where as the VF-1 has thermo-nuclear engines??? Quote
Lonewolf Posted July 30, 2007 Posted July 30, 2007 I'd say it's an animation error, but you could be right and it could very be because of the diffence in engine design. Someone in the forums must have the 411 on this. Quote
eugimon Posted July 31, 2007 Posted July 31, 2007 the vf-0 with it's conventional engines has to breath air at all times, since the engines provide electrical power as well as providing thrust, so it makes sense the shutters stay open. Quote
F-ZeroOne Posted July 31, 2007 Posted July 31, 2007 Actually, some of our mere Earth jet engines can be designed to be very tolerant of disturbed air flow - early MiG-29s had intake covers that could be fully closed in flight, and apparently it was possible to fly at up to about 300 knots or so with them closed...! (although there were vents on top of the intakes IIRC for air intake when the covers were closed). Take that, OverTechnology! Quote
eugimon Posted July 31, 2007 Posted July 31, 2007 Actually, some of our mere Earth jet engines can be designed to be very tolerant of disturbed air flow - early MiG-29s had intake covers that could be fully closed in flight, and apparently it was possible to fly at up to about 300 knots or so with them closed...! (although there were vents on top of the intakes IIRC for air intake when the covers were closed). Take that, OverTechnology! David can probably fact check this, but I thought that mig could also take off from a debris strewn runway just on those top vents. Anyways, the engines are still getting air, if from a slightly different route. Quote
Smiley424 Posted August 1, 2007 Posted August 1, 2007 Yes, that is correct AFAIK the Mig-29 has/had these covers which would cover up the main intakes for the engines (under belly intakes) and other vents would open on top. Actually though, from what I understand, the intake covers were not completely solid, but something more along the lines of a metal mesh or something like that to prevent sucking in debris (birds and such). Quote
Lindem Herz Posted August 1, 2007 Posted August 1, 2007 Mig-29A had the shoulder vents and a solid cover. Mig-29C has the mesh covers and no shoulder vents, the same as the Su-27 family (I guess they figured that having one set of moving pieces instead of two was better) Quote
