Kurisama Posted May 5, 2006 Posted May 5, 2006 (edited) Hello again! I've decided to have a go at the YF-21, since theres always somebody making VF-1's! Originally i wanted to make a Q.Rau - but that red one that was posted a while ago, was simply beautiful! no way i could do it justice! I am also looking into making a Renegade Q-Rau from M.Plus after this and the Octos, as i really like the design. I'm making this based off the Hasegawa model and am making it in all its pieces as i will later have it transform, i'm using the Battroid scratchbuild that was posted on these boards some time ago - for battroid reference, also helps that i have the design works books! Sorry about the lack of detail, as i started it a few days ago - also trying a new shader out for the first time. Thanks! Edited May 5, 2006 by Kurisama Quote
Kurisama Posted May 8, 2006 Author Posted May 8, 2006 (edited) Thanks guys! Here's an update; Parts left to model - entire arm units, entire leg units, the 2 flap thingies that cover the underside/attach to the hips and some greeble detail inside the YF-21 for use in battroid mode (between the 'backpack' and the torso) - not really needed but will look cool non the less. My main goal is to model it as low poly as possible without losing any detail, so it can have a flexible amount of usage. After the modeling has been done, i'll tackle the texturing - which i still need some practice in - urgh... Here ya go! Edited May 8, 2006 by Kurisama Quote
Malich Posted May 10, 2006 Posted May 10, 2006 Dude, that is freakin awesome! Keep up the good work! Quote
Dante74 Posted May 10, 2006 Posted May 10, 2006 My main goal is to model it as low poly as possible without losing any detail, so it can have a flexible amount of usage. 397625[/snapback] Isn't that allways the goal? j/k Great work! Can't wait to see it finished. Quote
Kurisama Posted May 16, 2006 Author Posted May 16, 2006 Hi guys, just a quick update, made the legs - sans the feet, still tweaking it, they're really skinny when in the hull cavity in fighter mode and they're a bit fatter and chunky in battroid. Next up - the feet, then arms! Yay. Quote
yf19-sama Posted May 17, 2006 Posted May 17, 2006 (edited) Keep posting! Don't let it down Edited May 31, 2006 by yf19-sama Quote
