Gah! for some reason all the glue decided to give out on my 1/48s, the landing lights and the small lil fins at the bottom of the nosecone fusilage all decided to give out at once :p what kind of glue does yamato use to secure these in place?
I'm not sure which glue Yamato is using for their parts? Actually, my 1/48 Hikaru came with a couple of lose panels (on the right wing) which I put right back on with some Crazy Glue. Also, my 1/48 Roy came with a lose panel on the right leg.........
You'd think that Yamato would use a better glue.........
I'd use PVA (white glue) for the landing gear lights. Super glue, if you use too much, or it oozes out of the seam you are re-joining can "frost" the clear plastic and ruin the piece. The red landing gear door light on my Max 1/48 is doing the same thing. Gonna zap it tonight before I lose it...
Super glue should work fine for the fins.
Edited by Macross Junky
I have been using zap a gap glue solely on my 1/48 and specifcally on the landing lights and the A head on hikaru and works fine. I use the pink zap a gap which is the thin style glue, I was very careful and have had no frosting yet. Be Careful!.
You mean the landing lights can pop out ???
Gotta check that out, this one would be a beotch to find on the carpet I tell ya.
Thanks for the heads up guys
(runs towards terrified battroid with my glue pot...)
