Here's a YF-29 Durandal that I modded shooting for a new Delta's VF-31 kinda look. Here's a color corrected pic I based it off of:
I bought the YF-29 used off of here and the central linking hinge beneath the canopy body was cracked and broke in half after just a few transformations
Bummer. It had to be repaired and it had lost it's resale value. I shaped a piece of aluminum and after fitting it with tiny washers it was actually good as new (if not stronger)
I got the bug to keep going however so this seemingly negative incident turned into the opportunity to mod it. I know the result isn't going to be everyone's cup of tea, but I really enjoyed doing it. First, I had recalled seeing this in a display online
I liked what I saw and adjusted the colors on another display to this
From here I thought I would try it. I used all existing parts, so in essence it was just a re-arranging of planes and parts (with some elimination of excess).
front
back
action
front
gerwalk back
What I was impressed by the original design was the consistent use of acute angles being all within 3-5 degrees of each other all throughout the airfoil pieces. The wings, rudders, canards, etc. all partake in a healthy share of similar acute and obtuse angles to create all corner edges of the various surfaces.
This consistency of angles made transitioning them to other parts of the plane a much easier task.
What I particularly like is that the wings still retract in and out like on the original (but without the engines) and has some VF-19 sweeping movement
So there you have it, when your valk breaks and you venture out to fix it knowing it's value's been compromised, being optimistic and doing something about it can help cuz I went from not liking it (when broken) to really enjoying it (when fixed).
